LUA access to Lvars?
I'm just starting to dig into LUA now that it's all contained within GIT. Milviz provide the following Lvars with "Lua" in their names. I'm puzzled on how I can use/set these Lvars from a LUA script?
setlvar("KAP140_LuaHDG_KeyDown",1) doesn't appear to do anything in my LUA script (LUA_KAP140_HDG.lua). So I searched for .LUA scripts thinking perhaps Milviz provided some, nothing found.
KAP140_LuaALT_KeyDown
KAP140_LuaALT_KeyUp
KAP140_LuaAPM_KeyDown
KAP140_LuaAPM_KeyUp
KAP140_LuaAPR_KeyDown
KAP140_LuaAPR_KeyUp
KAP140_LuaARM_KeyDown
KAP140_LuaARM_KeyUp
KAP140_LuaBARO_KeyUp
KAP140_LuaBARO_KeyDown
KAP140_LuaDEC100_KeyDown
KAP140_LuaDEC100_KeyUp
KAP140_LuaDEC1000_KeyDown
KAP140_LuaDEC1000_KeyUp
KAP140_LuaDOWN_KeyDown
KAP140_LuaDOWN_KeyUp
KAP140_LuaHDG_KeyUp
KAP140_LuaINC100_KeyDown
KAP140_LuaINC100_KeyUp
KAP140_LuaINC1000_KeyDown
KAP140_LuaINC1000_KeyUp
KAP140_LuaNAV_KeyDown
KAP140_LuaNAV_KeyUp
KAP140_LuaREV_KeyDown
KAP140_LuaREV_KeyUp
KAP140_LuaUP_KeyDown
KAP140_LuaUP_KeyUp
Any hints on what I might be missing as I guess I don't understand the purpose of these Lvars that Milviz define?
KAP140_LuaALT_KeyUp
KAP140_LuaAPM_KeyUp
KAP140_LuaAPR_KeyUp
KAP140_LuaARM_KeyUp
KAP140_LuaHDG_KeyUp
KAP140_LuaNAV_KeyUp
KAP140_LuaREV_KeyUp
KAP140_LuaUP_KeyUp
Does the lvar appear/work in Detective?
KAP140_LuaHDG_KeyDown is not mine, none of those are mine, it's what your code detects for Lvars. I honestly don't really understand the purpose of them ... MV have some KAP140 documentation where it lists these Lvars but doesn't same anything about how to use them or what they do. MV don't provide any .LUA scripts so I'm puzzled?
Using detective it appears the KAP140*_Lua*KeyDown Lvars are set when the corresponding button is clicked in the VC. The "KeyUP" Lvars are never set. So I emulated setting the KeyDown LVars in my Bespoke along with other Lvars and events that got triggered/set.
So last night I was able to get KAP140 HDG/ROL button to work as expected but was entirely based on what I found via GIT detective and I didn't use any LUA scripts. LUA scripting certainly can do some powerful stuff, but I honestly could not find a need for it ... but if you have any clues/insight on why Milviz would provide those Lvars that might help me understand?
I would try setting the down key and then the up key lavrs and see if that works.
Yes, setting the KeyDown along with other Lvars and events did work. The KeyUp never gets triggered or is never visible to detective.
I did search for all *.LUA scripts and found a few but none were related to Milviz or the KAP140 ... but all is good now without using any LUA scripts. Just need to wrap a few things up and check a few things then get the file posted for others to use.
Thanks, Robert
