Change Log - Virtual Flight Sim Hardware
1.1.0.0
- Updated PMDG 737 support to work with latest version.
- Fixed missing code to properly support PMDG 737.
- Added support for rotaries connected to displays that cycle allowing the configuration of rotary events to change the current displayed data.
- Client app image caching improved to stop corrupt displays. If problems remain, the Image Loading Timeout option in the client apps settings can be increased until it works correctly.
- Windows/UWP client app contains work around to fix wobbling rotation of images (Xamarin bug)
- Added MCP IAS speed symbols for the PMDG NGX/NGXu/737/736
- Added support for interim PMDG 737/736 SDK that supports updated versions of the initial 737 release.
- Adding functionality to update PMDG ini files to enable the SDK for the NGX/NGXu/777/747/737/736/738/739.
- Export now correctly exports override Snippets.
- Fixed bug where Gauge state configurations would not save settings correctly when not created via a Snippet.
- Fixed major bug where image paths would be wrong if Documents and ProgramData directories were not on the C: drive.
- Added the Event Action MOUSE_RIGHT_X2_SLOW for PMDG 747 gear.
- Added better support for detecting FS2020 is in "Sim Mode".
- Fixed Export errors caused by missing directories for Power Configs in Flight Sim IO Server.
- Added integration support for GoFlight Interface Tool Visual Edition.
- Added Lua extensions, setwp6colour and setwp6color for GoFlight Interface Tool Visual Edition.
- Bespoke Event Keyboard support for FS2020 now works.
- Removed duplicate execution of lua scripts for global.lua and global_aircraft.lua which were causing errors to appear in the log.
- Added support for X-Plane 12.
- Corrected default value for Device Panel Lighting Level.
- Fixed bug where X & Y positions of parts could be set to 0 when loading if the previous canvas was smaller than the canvas size being loaded.
- Added view option to hide connections.
- WASM module no longer reports lvars from previously loaded aircraft.
- Start Bespoke Events now execute.
- Fixed issue where latest lvar values would not be received if FlightSimIOServer was shutdown and then restarted.
- Fixed issue where Bespoke Events could be wiped out under certain error conditions.
- Fixed issue where non decimal values would not display leading zeros.
- Fixed issue where FlightSimIOServer would lock up when running Detective and the flight sim was shutdown.
- Fixed issue where changing aircraft would not load aircraft specific Bespoke Start Event, but keep the one from a previous aircraft.
- Fixed bug where data driven lit components were not updating their lit states.
- Added IAS_MACH_INTEGER_BLANK Display Action that will always display speed as an integer even in Mach mode.
- Lua console window now closes on Windows 11.
- FSIOServer no longer hangs waiting for FlightSimIOLua to close.
- Testing the Start Bespoke Event now cancels any running Start Bespoke Event.
- IAS_MACH action now works correctly when in Mach mode.
- Updated A320 Neo (MS2020) Bespoke Events to work with new autopilot variables.
- Updated 737 (MS2020) Snippets and Bespoke Events for better support.
- Fixed bug where a lit method change would not be picked up by the FlightSimIOServer until the software suite had been restarted.
- Correctly named the ALTITUDE_SLOT_INDEX_SET event from AP_ALTITUDE_SLOT_INDEX_SET.
- Detective now adds the correct variable index when filtering stopping hidden variables being included in monitoring.
- The Task Call Bespoke Events can now call Lua scripts.
- Detective now correctly stores if a Bespoke Event runs in the background.
- Lua setsvar and getsvar commands now work correctly regardless of the variable syntax used.
- Editing a Set= Task now correctly tracks and restores previously variables and applied filters.
- Fixed issue with 2 way white long switch not being referenced in modules that were using it, they were referencing an old copy of it.
- Android client now installs only 1 icon.
- Import function thread owner error fixed for some import situations.
- Fixed various minor bugs/issues.
1.0.4.0
- Added support for the PMDG 737 for FS2020
1.0.3.0
- Removed Guid from Label Task name.
- Part selection of a rectangle in Config mode will now drill down to find a Fitted Component/Fitted Component Instance
- Fixed issue where default Lit Methods would not be created for a new flight sim.
- Fixed issue where Snippets store would save unencrypted in some situations.
- Fixed bug where selected Part would lose its adorner when entering Config Mode.
- Fixed issue where Data Driven Lit Components would light up when used even though no power was available.
- Fixed issue where Data Driven Lit Components would stay lit even though no power was available because the Variable/Dataref did not change.
- Fixed exception caused by global/aircraft Lua scripts attempting execution before connection made.
- Fixed bug where default Snippets being deleted in Device Panel mode would leave orphaned Snippet labels on any Modules using that Snippet, even after running Update Pending Snippet Changes
- Fixed bug where Lit Method variables that continually would bombard the Client App with updates causing it to slow down.
- Improved Variable/Dataref selection in Detective when un-hiding a Variable/Dataref.
- Fixed bug in Virtual Hardware Builder that would not show a second Custom Value field when _SPIN_DATA was the Event assigned.
- Fixed bug where the _SPIN_DATA Event would only work on State 0.
- Added _SPIN_DATA Event support to Selector Components.
- Fixed issue where Variable Custom Value 2 would only show in State 0.
- Fixed bug With DATA_DRIVEN_BIT_SET, DATA_DRIVEN_BITSET_OFF_IS_1 and DATA_DRIVEN_REVERSE_OFF_IS_1 Data actions returning wrong values.
- Added DIVIDE_AS_DECIMAL_TO_DEGREES, MULTIPLY_AS_DECIMAL_TO_DEGREES, DATA_DRIVEN_EXCEPT_OFF_IS_1 and DATA_DRIVEN_REVERSE_EXCEPT_OFF_IS_1 Data actions.
- Fixed bug where a selected Fitted Component Instance would lose its Snippet assignment when switching from an aircraft to default config.
- Fixed bug where changed Events & Variable indexes where not being reset, if changed to no valid Event or Variable.
- Fixed bug where Lua scripts would not appear in Virtual Hardware Builder or be executed until the Flight Sim IO Server had been restarted.
- Added support for unknown Events.
- Added Snippet copy function.
- Event filters are now cleared when aircraft is changed in Detective and Lua.
- Fixed bug where State Configurations would not be processed if they were created in a random order.
- Fixed bug where Detective Variable/Dataref would not be removed from hidden list when requested to do so in some situations.
- Fixed slow searching for Snippets.
1.0.2.0
- Fixed bug where two labels with the same text, but one being Lit and the other Unlit would only produce the Unlit label.
- Fixed bug where in some situations, two tablets loading the same Device Panel, only the first loaded would get updated Lit Methods for the Modules.
- Fixed bug where the side panel would sometimes be visible in Component mode.
- Added Parking Brake Toggle Snippet.
- Adding Panel Lighting to Radios Device Panel.
- Fixed bug where a Data Driven Lit Method on a Component would ignore a Lit Method Override from a Module or Device Panel.
- Fixed bug where a Data Driven Component would light up even though power was not available.
- Fixed bug when deleting a Component/Module/Device Panel/Device Panel Group without the FlightSimIOServer running, would cause a lock up when changing mode in Virtual Hardware Builder.
1.0.4.0
1.0.3.0
1.0.2.0
This discussion has been closed.
