MCPPRO / EFIS no longer works with the latest XPLANE12 update
Hello, since the last update of Xplane 12 and with the 737 ZIBO, I have just noticed that my EFIS no longer works at all and that on the MCPPRO only the IAS/MACH wheel no longer works. Does anyone have a solution? Thanks in advance
  • Are we alone on the forum now ? :'(
  • Have you tried reloading the profile?
  • Hello,
    I'm very happy to hear from you, but I can't download the profile. My command appears correctly, but I can't download GIT XPlane.zip. Could you tell me how I can download it? Thanks for your reply :)
  • From here https://www.pollypotsoftware.org.uk/downloads.html on the GIT Aircraft Config X-Plane tab and look for the ZIBO in the list. Backup Documents\GoFlight Interface Tool before loading the profile.
  • Hello,
    I've done this several times by downloading the ZIBO profile, and the problem persists on my EFIS and MCPPRO, however, I can no longer download the GIT software from the downloads. I would like to try uninstalling and installing the main software. What I don't understand is that this worked perfectly before the Xplane update. Thank you for your reply. :)
  • I am having no issues with my EFIS, MCPPRO and GF166 profile and the latest X-Plane 12 beta 12.3-0 Beta4. Have not had any issues with any of the previous X-Plane releases and GIT.
    I do sometimes lose bindings through GIT, but then I just import the profile again, and all is back to normal.
    And YES I did export my EFIS, MCPPRO and GF166 profiles as a backup. Something I highly recommend.
